Question about Allen & Heath Music
Hello, I was working at a outdoor festival recently, nice dry weather, approx. 75 degrees outside. We were running three stages and my fellow sound tech was using one of my GL2400-32 channel AH mixers. He started the show and then noticed the mixer was shutting down, He could see the power supply lights going dim, cutting off then back on. It was running on the internal pwr supply only. A burn smell was coming from the mixer. He told me the power supply was going bad. I do not know what connections he had made to the mixer. Unfortunately I could not get any more info from him because we have parted ways. I have not seen him since. I purchased this mixer as a new store demo and this was the first time I had used it. I connected it in my shop and run it for 24 hours with no issues. It still has the burn smell and it seemd to be coming from somewhere near channels one through 16.I have the back removed and need a way to thoroughly test each channel.I have a replacement power supply and also an external power supply but the burn smell seems to be coming from somewhere else.Could something have been connected to a channel to cause this kind of damage? Could a short in a input with the phantom power on cause any damage? Thanks Steve
Posted by theareys on
electronic & computer repair& servicre
  • 12,061 Answers
Cachepe.samedaymusic.com/.../gl2400ug_ap5597_2-42fad5e2de1bc79db38576be174464d4.pdf - United States
Above is your user manual below is a service and repair manual.
http://www.performanceaudio.com/cgi/product_view.cgi?products_id=16696
Indeed i would suspect something around your Final Output semiconductors, and any associated resistors?
You really must obtain a service manual, here there are the troubleshooting steps required to isolate and hopefully allow repair of your unit.
Look for any discolored components etc, check if any are overly hot... use a temperature probe on suspected components. Freeze spray may also be useful in diagnosis.
Use your eyes & nose to isolate the bad burnt overheated components, I sometimes use a straw up a nostril and selectively go over suspect parts, and "Sniff" to try and detect the overheated smell... it works.
http://www.allen-heath.co.uk/uk/TechnicalSupport.asp
Above is your tech support link, contact them for any info you require.
Posted on Nov 30, 2010
Woofer rattles at low volume...when i turn it up it sounds pretty good...still has bass and highs
May be a couple of things; The first is a resonance in the cabinet, which may not be noticeable at high volumes. If the speaker cabinet was ever dropped,or got cracked from dropping , dry weather,or whatever, there may be certain frequencies that make the cabinet rattle. Try holding the cabinet when it rattles and look for anything loose,from a side wall to a loose foot, or the speaker itself. Tighten up loose items and seal any gaps or cracks On the cabinet.
The other problem could be a partially blown speaker. Test by lightly pushing in on the outsides of the speaker to see if it moves in and out freely. If there is a scratching sound, or it drags slightly , it might be blown. Also,the dust cap or another part of the speaker may be loose. Check that, and reseal if loose. Replace or have reconed if blown.
Nov 02, 2014 | Mackie MR8 ACTIVE STUDIO MONITOR MR-8
Serious Doubts of Authorized Delaers
I think you have been lucky! Many manufacturers do not want you to do your own servicing or updating, and guard their Technical stuff jealously. Letting anyone use it opens it up to copycat manufacturing.
Mar 14, 2014 | Numark Industries Numark 5000FX 5 Channel...
I have a line 6 spider jam ...was playing guitar and then the sound went dead... loops work lights work but no sound
It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
Oct 22, 2013 | Line 6 Spider Iii 75 Guitar Combo...
I Have a GL2400 Allen & Heath Console. The other day we were working out doors at a Festival and all of a Sudden I stopped receing signal to the Console. I tried all chanels and got the same result. I...
I will ask a question: Did you remember to power ALL inteconnected equipment from the SAME and I do meanALL and SAME receptacle or power conditioner module? If you powered your stuff from several receptacles in a large venue, likely ground system bounce has caused damage. I don't know what you mean by "dont get any signal in."... explain that... There are tests to run to isolate the problem but if you got hit with ground bounce transients you could have major damage. That is a big board for an outside venue so you might describe what you had configured from mics, etc. to speakers. ALL professionals know to run power back from where their amps are to the mixer alongside the snake. I will give you points for carrying a spare... ALWAYS a good plan as electronics DO fail and of course at the worst time.
Aug 24, 2011 | Allen & Heath Allen Heath GL2400 32 Live...
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
DJ LIGHTS
MOST DJ lights are not protected to be used outside in weather.
Other considerations are visibility from highways and also aircraft. Certain lights could cause a problem for these two scenarios.
When outside, often the distances are longer and the light drops off as the square of the distance.
Laser types require fog to get the effect and there really isn't a way short of getting the weather to cooperate and give you fog to get those effects.
Between the laws of physics and the construction of lighting intended for interior use, what you are asking for is just not easily obtained.
The inability to control ambient lighting outside is a real problem. Many of the DJ things require a fairly darkened room. The sky glow from a city is enough to kill off the effects.
May 19, 2010 | American DJ Flash Beam Lighting Effect
Marshall MG100HDFX 100-Watt Amplifier Head. The head phone jack works but speaker output is dead. Hooked it to speakers with another amp input and after word it stopped working. Can't see any overheated...
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
Nov 26, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Low volume on acoustic and jazz amp type
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Apr 01, 2017 | Fender Fm25dsp 1x10' Guitar Combo...
Music Logo
440 people viewed this question
Top Allen & Heath Music Experts
Marvin
Marvin
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
