SOURCE: ipod only shows outlet
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
SOURCE: 30 gb apple ipod...
try to access the Settings on the iPod menu and locate the section where you tell it to charge.
SOURCE: I've a A1059 Ipod Model.
In many cases, the 20gb Classic and Photo models have problems with the Hard Drive. I have found over time, if you open the iPod, and remove the hard drive from the cable, remove the cable from the board and assemble it back together in reverse the problem will go away. The ipod cables tend to seat and don't make good contact.
to open your ipod, lay it on it's metal back, slide a guitar pick down the side between the metal case and the plastic front. slide it up and down the length of the ipod.do the same to the top and bottom. it should pop open. Up near the headphone jack and switch the is a cable attached, be careful not to open the ipod to fast, use a guitar pick to pry up the cable from the mother board and that will expose the inside. Now to remove the hard drive hold the black tab on the hard drive cable and pull the hard drive free straight back from the cable. To free the cable from the motherboard, lift the black lever clip up and open. now look at the cable end. If it is v shaped, straighten it and reinsert it in the motherboard and puc the black clip flat again. reassemble the ipod and give it a try.
SOURCE: Need to download Manual for iPod
You can go here and read and even download the manual if you want: http://manuals.info.apple.com/en_US/iPod_nano_4th_gen_UserGuide.pdf
SOURCE: Apple Nano Chromatic Silver Ipod 8 GB only works in the charger?
buy a new baterie from global sources in brampton ontario
