VuPoint PDSST410VP Logo
Posted on Nov 30, 2010
Is there a operators manual for the VuPoint Magic Wand portable scanner? How do you access the items you scan? There are no instruction on the one page sheet. Do you use the cord to go directly to the computer or do you remove the scan card and transfer it to the computer.) How do you tell the scanner to scan a document or a photo?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2351
Points
Plz ask how to use?
I am going to purchase at Wal-Mart SKU:ADIB002R0BFAA VuPoint Solutions Magic Wand Portable Scanner I don't know which SD care to purchase to go with it?
Anything larger than 1 GB is ok. There is no specification the more scans you want to do, the bigger the card should be
I have a line running through the scans. What do I do?
Try cleaning the scanner glass very well it will help you
Why do i have a white strip down my scan
CHECK TO SEE IF THERE IS ANY DEBRIS ON THE SCANNING ROD THAT PICKS UP IMAGES.... THAT WILL CAUSE THE WHITE LINE.
VuPoint Magic Wand scanner. I'm very happy with the quality of the scans, but the problem is that the PDF and JPEG files that it creates, even on low, mono resolution, are huge.
Look for the firmware update for your specific model and download and install make sure you choose the right model. You can mess up your scanner completley if you choose the wrong one. Software Driver Downloads User Manuals Warranty Card
When I scan something with my magic instascan I can not find it on my computer. Doi need to install something first?
Make sure your wand is turned on. You have a microSD card inserted in the Magic Wand. Go to "My Computer" and look for a removable disk drive.
5helpful
I lost the instructions for my Magic Wand portable scanner.
Hi jwilli3306,
Visit this site to get your Instruction Manual for your sepcific Model :
http://www.vupointsolutions.com/downloads.php?d=manuals
I hope this helps, good luck!
10helpful
3answers
How do you remove the top of the Magic Wand Portable Scanner to install the batteries for Vupoints model # ST415 magic wand?
The battery cover is the silver-colored "hump" on the right side of the scanner. Just slide it to the right, and it'll unhook from the scanner, giving you access to the battery compartment.
Top VuPoint Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a VuPoint Office Equipment and Supply Expert? Answer questions, earn points and help others
