I think I found a solution: this appears to be a single-outlet version of GE 06655 Light-Sensitive 8-Hour Dual-Outlet Timer. I have tried matching the dial settings from the online image and it seems to work. There are seven settings on the timer switch. Set the pointer of the rotary switch dial so the ridge clicks into place with one end pointing precisely at the triangular switch position indicator. This is the Off position. Turn the dial one click clockwise, this is the Always On position. Then comes the 2-Hour setting, meaning it comes on at dusk and turns off after two hours. Then come the 4-hour, 6-hour and 8-hour settings. Finally, the Dusk-till-Dawn setting.
I don't have GE number like that.
It may be old GE number, but internet does not show result for '58280 timer' except your question.
GE timers are usually 15000 numbers.
Woods timers are 50000 numbers.
I cannot find any timer with 58280 number, and I have files full of timer numbers.
I research and test timers, and I don't know that number.
Nor can I imagine stick-on label or stick-on dial goes on timer.
Give me more information: What does this look like. What does timer turn on-off. Is this a programmable timer. Is timer plug-in or installed in-wall. Is this indoor or outdoor timer. What did label have printed on it.
Take photo of timer and post it on Imgur.com, and then include Imgur url (for example imgur.com/DF45E)
With further information, I might be able to help get label for you.
I have the same model, same problem, the timer sticker has fallen off. It does say Cat No 58280 on the back, I think I got it at Target, maybe it's specially labeled. It is an outside-usable timer switch with several settings: always on, 2-4-6-8 hours on at dusk, dusk-to-dawn. Single, grounded outlet, 1000w rated.
