basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me,
[email protected]
