Question about Hitachi 50UX57B 50" Rear Projection Television
Colors on tv are seperating. looks like double images.
Posted by justin4ut on
Anonymous
  • 476 Answers
Hi, Try the auto convergence or auto focus to eliminate the problem, if this does not work, you may have to get the TV repaired, the common problem are the power amplifiers that correct the color convergence, that is why you get color shades or ghosts in the images.
Posted on Nov 29, 2010
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: COLOR SEPERATION
converge ic's
Posted on Oct 08, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Hitachi 42" Wide Screen TV - color seperation, double images
Replace Both of your convergence ICs they are big black ICs and ck resistors RK4246,50,54,58,62 i have the values if you need them they are 1.5ohms up to 3.9ohms.ICs will have STK392-110s if this is the number on yours upgrade to 180s
Posted on Feb 19, 2009
Hitachi-mex
Martin Wong
  • 26 Answers
SOURCE: colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Posted on Apr 16, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
Anonymous
  • 125 Answers
SOURCE: My rear projection Sony TV looks like it is seeing double images.
Yes Replace Both of your STK ICs they are big black ICs will have part number on them STK392-110
if they are 110s use 180s Better ICs Mats Electronics has them 1-800-628-1118
Posted on Mar 25, 2010
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
The screen has a double image and also has a
u have bad convergence , this is a problem from the deflection board , the repair of this repair is about $250
Apr 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 57'' rear projection tv has double images on both sides.
tv looks in the center and have double and multiples colors . majic focous do not fix t
Jul 13, 2009 | Hitachi Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Colors have seperated on tv, and curve
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Feb 19, 2009 | Hitachi 43GX01B 43" Rear Projection...
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
511 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
