Question about Home
How to unclog dog hair ?? I have 2 large dogs and tons of dog hair have gone thru my automatic wash machine which shares pipes thru the adjacent wall where my kitchen sink, automatic dish washer and waste disposal are. Now I all appliances mentioned are backed up with water.
Posted by robertnate on
mike rondeau
    New Friend:
  • 118 Answers
Use a drain snake
Posted on Dec 06, 2010
Kenmore/Whirlpool WASHING Machine #110.26752502 top load Not Rinsing Thoroughly
usually the dogs in the upper agitator go bad. your agitator is two pieces. grab the lower agitator and turn the upper agitator. if you can turn it, the upper, back and forth. the dog cams are bad. very common problem. if they are stripped, clothes will not agitate in wash or rinse. plus machine can go out of balance easy. usually caused by normal wear and tear but is also a sacrificial piece in the even of an overload. common tools repair. good luck.
Kihm Skillicorn
Jun 14, 2017 | Washing Machines
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
Washer not draining
Please be specific about the washer...
Dec 06, 2017 | Maytag MAV7501 Top Load Washer
I just did a load of dog blankets, everything washed nicely, cleaned out the hair,put another load in of clothes, pushed the power button, heard a beep, pushed start and nothing happens.
Remove bottom panel.0da3616.jpg Get dog hair out of pump housing.a18b640.jpg
Tech sheet will be on that panel or behind that white box to the left.385ce31.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Odor in washer
Try running a cup of white vinegar thru it, usually helps
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Sep 28, 2008 | Home
Home Logo
136 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
