Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list. Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
You need to use the Sansa Media Converter to convert the photos to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
In addition, make sure the photos are on the Sansa itself and not on a memory card.
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
If it's an SMC with a little luck you'll find the drivers for your specific model number, Otherwise, go to SMC Site and search for your model number. If it's not an SMC device, let me know what brand and model number it is.
The Sansa will not play videos off the microSD card. It will play music, but not show videos or photos.
To get the videos onto the Sansa, use the Sansa Media Converter. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
The Sansa will only show photos and play videos from its internal memory, not the microSD card. You can put music on the card, but not photos or videos.
