Question about Apple iPod mini M9160LL/A MP3 Player
Hi guys, I have an iPod (model A1051) and whenever I connect it my laptop, it is not recognized, except that the battery charges, and is appearing on his screen a battery with a warning sign (a triangle and an exclamation ) as if it had no battery. the ipod is already carrying more than one hour and will not turn when I shot it off the usb cable, and I can not turn on and when I reset it, the apple does not appear. HELP ME PLEASE
6ya staff
SOURCE:
Anonymous
  • 30 Answers
SOURCE: Sad Ipod sign and B&W charging battery sign....
Have you tried reinstalling the drivers?
Posted on Apr 06, 2007
Anonymous
  • 150 Answers
SOURCE: my mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Posted on Sep 14, 2007
Anonymous
SOURCE: Apple iPod Nano Model A1137
no video conveter in A1137 whyyou have not given the conveter
Posted on Aug 23, 2008
mneilsen2084
Mel Neilsen
  • 342 Answers
SOURCE: My Computer and iTunes does not recognize my iPod
If your ipod is not recognized by either the computer or itunes try putting the ipod into disc mode and reconnecting the ipod.
Make sure you have the latest version of itunes by opening itunes and in the top tool bar click on Help; you will then click on About itunes. If it is not itunes 8, you will need to update that first.
Here are the steps to putting an ipod into disc mode...
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
Once you have gotten the ipod into disc mode go ahead and connect it to the computer. It should show up in itunes at this point. So long as it does you will want to restore it, and just in case your not sure as to how to do that here are the steps for that as well...
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
After completing the restore process, eject the ipod and disconnect it. Reconnect it and see if it shows up normally again. I hope this resolves your issue :) CHEERS
Posted on Apr 23, 2009
Anonymous
  • 21 Answers
try to plug it on the socket wall and charge it for about 2 to 3 hours and connect it to your pc it works
Posted on Apr 27, 2009
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apr 23, 2009 | Apple iPod mini M9160LL/A MP3 Player
Drivers for IPOD 4GB PINK
I want driver for IPOD .
Mar 01, 2008 | Apple iPod nano
Ipod charges,heats up on bottom right.Battery dies fast.Replaced battery,still same problem
It sounds like the battery has shorted out. Ship this guy out and have his battery replaced ASAP! This is a giveaway with the heat. Please note that it is "problem solved!"
Jul 27, 2007 | Apple iPod MA446LL/A MP3 Player
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Charging icon
For windows users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes. The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. Here's the animated version you would see after 10 minutes, or when the battery is not fully drained: If the charging icon is flashing and your computer doesn't recognize it, Can't see your iPod in iTunes or Windows Explorer? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below?you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. iPod appears in Windows Explorer but not in iTunes or iPod Updater If your iPod shows up in My Computer, but iTunes and iPod Updater don't recognize it, there may be a software conflict, or iPod Service didn't load. You may see an ""iPod Service Error"" alert or a ""Please Reinstall iTunes"" message. If you see either of these messages, try the solutions in this article to resolve the issue. Laptop or portable connecting via USB? See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh
Apple iPod mini M9160LL/A MP3 Player Logo
311 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
