Question about Samsung Microwave Ovens
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be there is a fuse or reset button somewhere? If so, is it something we can access or do we need a repair person? Model SMH7178STE Serial Number 7MTL7001236L 1.65kW Manufactured July 2006 in Malyasia 120 Vac 60 Hz
Posted by lee9106 on
Anonymous
    Genius:
  • 1,196 Answers
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Posted on Nov 29, 2010
  • Anonymous Dec 04, 2010
    Most ranges today
    use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud
    buzz noise when setting or unlocking the lock and has a arm that you must move to set the
    lock )...another is a heat sensitive lock ( has a arm that you must move to lock and
    un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven
    is heating up )...Some locks are motorized ( no handle to move, the motor locks the door
    by it's self when you set the range for self clean )... If the motorized and heat
    sensitive locks fails to open after the self clean cycle, you must access the lock and
    move it yourself to open the door. On the free standing ranges, most times you must lift
    the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out
    to remove the top access panel to get at the lock mechanism. Some build in ovens can have
    the control console removed to access the lock system. On the
    heat sensitive style of lock, there are no
    electrical parts to operate the lock, usually you will need to replace the lock.
MY MICROWAVE LIGHTS UP AND THE TURN TABLE GOES AROUND BUT IT DOES NOT HEAT ANYTHING UP? EVERYTHING ELSE WORKS ON IT!
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 23, 2010 | Whirlpool MH6150XM Microwave Oven
Samsung smv9165 microwave setting wont heat anything up,seems to power up,table turns vent kicks on ,but food is still cold ,convection setting works but not microwave setting
Replace the magnetron and diode. The parts place will know what your talking about. But it would easier to buy a new one honestly.
Nov 30, 2009 | Microwave Ovens
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo microwave model em-s5002w won't heat...sounds louder
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Feb 01, 2009 | Microwave Ovens
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Microwave no heating
It sounds like the magnetron failed.
Check this link for more info and maybe a way for you to test it for functionality. If you are uncertain on what and how to do it, I would suggest to take to a repair tech.
Feb 27, 2008 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
