Question about NEC Versa VX Notebook
My laptop battery not charging - NEC Versa VX Notebook
Posted by zebijan786 on
Lee A.
  • 4,472 Answers
First thing to do would be to try replacing the battery. If the problem persists there may be a problem with the charging circuitry in the laptop itself.
If you need further assistance please let me know.
Thank you,
lee
Posted on Nov 29, 2010
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
Dell Xps 15 Laptop Battery Not Charging
To test the laptop:
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Battery will not charge.plugged in not charging
    Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
    A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
    If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
    Hope that's helpful.
    Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
    NEC Versa VX Notebook Logo
    293 people viewed this question
    Top NEC Computers & Internet Experts
    Ekse
    Lee Hodgson
    Lee Hodgson
    Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
