If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
The long tone and flashing light has to do with your firmware. If your mac boots up, you could try to download the latest firmware update and install it. But more than likely you will need to take this one into the shop.
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
When you reboot and hold down the option key, does the drive show up during that initial process?
Is the weird noise more like clicking or more like a high-pitched whirring?
If the drive has been damaged on a hardware level (causes too numerous to list... age, power fluctuations, being knocked over or dropped, corrosion, poor workmanship...) and won't show up at all, it is probably now a paperweight.
There are a couple of utilities available to troubleshoot disc problems for Macs. The most popular are Disk Warrior and Tech Tool Pro. They can often "see" a disc that Disc Utilities misses, and assist you in copying the data from the drive. This process is important to be cautious with, however, since your drive is making noises it should no longer be considered reliable and the best hope is to retrieve your data and then get a new one or have yours replaced [if it is under warranty].
