Question about GE Profile WPRE6150KWT Colossal Capacity Washer
The motor has a power inverter on top of it. Try and reset the motor by doing this:
Turn the washer off. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. It may take a few times. The motor has a green light on it that blinks. If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire. If you see a liitle bubble in there then you know that dude is toast.
That fuse is: $7.50
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 29, 2010
Jan 31, 2018 | Kenmore 24032\24036 Top Load Washer
Sep 04, 2013 | Electrolux EIFLW55I Washer
Oct 27, 2012 | LG WM1814CW Front Load Washer
Sep 01, 2011 | Maytag Performa PAV2200
Dec 15, 2010 | Kenmore 24032\24036 Top Load Washer
Dec 02, 2010 | LG WM-2277HW Front Load Washer
May 28, 2010 | General Electric WCSR2090D Top Load Washer
Jan 21, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Dec 25, 2007 | Washing Machines
692 people viewed this question
