Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I have a dyna glo pro heater that I am using diesel fuel in. The heater has been working fine but now it is leaking fuel out the front and shuts off. E1 shows up on the digital panel. when it shuts off it smokes excessively. any suggestions
Posted by buddyparris on
5 Related Answers
Anonymous
  • 625 Answers
SOURCE: dyna-glo
try this site - they have dyna glo parts
http://www.robinrents.com/heaterparts.htm
Posted on Dec 11, 2007
Anonymous
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
Anonymous
SOURCE: dyna glo kerosene heater
smoking problem
Posted on Nov 23, 2008
Anonymous
  • 92 Answers
SOURCE: filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Posted on Jan 22, 2009
Anonymous
SOURCE: dyna glo workhorse heater
you need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Posted on May 06, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
Hi i have a dyno glo pro heater model number RMC-KFA170TDGP it worked great last year this year its been nothing but a pain flames shoot out the front by times sounds like its getting to much air but the...
did you try cleaning the lens of the photocell, they git dirty from smoke ver time which regulates the flame or replace the nozzle, sounds like it could be getting plugged up? usually any heating store would have a nozzle for a couple bucks if you get the number off it. the nozzle is right where it comes out and they are common to plug up at times with wear
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
My heater will shuts off automatically
lp or natural gas sounds like moisture in the line look for a trap should look like a tee with a cap on it turn off gas and remove cap and see if any moisture in line replace cap and turn on gas check for leaks with soapy water and a small brush if not moisture it could also be air in line if so it will bleed itself out in a little while and work normally
Dec 17, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Filters for dyna-glo pro
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
493 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
