I have a Kenmore 70 Series. I have had several issues with the water level does not stop filling ans overflows. If the knob is not set EXACTLY on the level desired the machine will run for ever. is this a switch problem or operator issue?
Vince
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Two screws on right/left of head, flip head back. You will see a small motor on the timer that operates when the timer is set. If this isn't running, then you need to replace that or the entire timer. Probably easier to change just the motor.
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
This problem is generally caused by a pressure switch failure. The pressure switch controls when to shut the water inlet valve off at the appropriate level and is located behind the load level or water level selector knob on the operator console. Before assuming, however, that you have a defective switch, read the following link first:
In the majority of the problems I have experienced with an overflow condition on a washer, it has been caused by the air hose coming off the pressure switch. Hopefully, this will be the case with your washer and will not require parts. I hope you find this information helpful. Let me know if you require additional assistance.
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
