Question about Crosley Radio Pictograph Slide Negative Scanner 1 ea
Having trouble with this product (crosley #CR5503A) on a windows 7 system. Seems to load okay to a point and then cannot get final steps to load. Does work ok on my older windows XP, can you help? Steve
Posted by kckaup on
Anonymous
I had the same problem today. I ran Windows "Mr Fix It" and that corrected it.
Posted on Nov 30, 2010
How do I access the drain pump on a crosley front load washer model number cfw4700lwo
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Feb 22, 2015 | Crosley Washing Machines
Won't load windows
You may want to try pressing F11 before the Windows Logo screen and select the option to restore from a previous point.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01835735&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=4007372#c01835735_command
Using System Restore when Windows 7 cannot start normally Use the following steps when Windows does not open normally.
Show me how
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F11 key repeatedly as the computer starts.
  3. Under I need help immediately, click Microsoft System Restore.
  4. Use the steps in the Restoring Windows 7 to a previous point section to use System Restore.
Jan 05, 2015 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Where is a Crosley repair facility?
If you registered the product with Crosley you can contact them.
Otherwise it seems you have to contact the distributer of the product for the nearest service center.
May 07, 2014 | Crosley CR248 Turntable
Reboot acer aspire 5710/5710z/5310 series to factory settings
Step 1:
Perform a system Restore.This process assumes you are in Windows 7.
Step 2:
Go into the Start Menu, and type "System Restore".
Hit 'enter' on the first result.
Step 3:
Select "Choose a Restore Point" and select "Next".
Step 4:
Finally, select the earliest restore point, and click Restore.
Dec 09, 2012 | Computers & Internet
I have installed Windoows 7 on my Dell OptiPlex GX620 but the audio drivers is not installed
I would try these two steps. 1. Open Internet Explorer and go to google and search for "Download VLC Player". Look for the site www.videolan.org/vlc and click it to go download vlc. VLC is a powerful open source media player that plays things the normal windows media player cannot handle. It's completely safe and it's faster to install and operates smoothly. It also copies down all the audio drives and codec that it needs. I have seen times that once it is installed, windows media player audio starts working properly too. I step one does not give you sound try step two. 2.Click Start and right above it you will notice a search box where you should type in "create a restore point". Click Create a Restore Point and follow it to create yourself a fail safe method of restoring you computer back to this point of just before you tried fixing the audio drivers. Give the restore point a name such as "I created this". Don't worry about a date and time, the system will automatically attach date and time. Once you've created a restore point open Internet Explorer and go to google and search for "Dell Support". Look for drivers and downloads and select the option to Choose from a List of Products. Your product will be Desktop/Dell Optiplex GX620. Once you've entered everything correctly you will see the drivers for the GX620. I looked and there are no Windows 7 Drivers loaded so that tell me that the Audio Driver for your previous operating system before you loaded windows 7 might be compatible. Select your previous operating system and then download and install the Audio Driver. If you have problems you can click Start/Programs/Accessories/System Tools/System Restore. When system restore opens up if the restore point that you created is not shown look for Selecting Additional Restore Points so that you can find the one you created. Select it and sit back and be patient while windows restores your system. *** You only need to restore if your system is going crazy on you.
Mar 14, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Wondered i f you could help..My daughter has an Easynote TJ67 laptop with Windows 7& seems to have changed the default access programs somehow... Everything now seems to be now set to Internet...
You can do System Restore to bring back previous settings, how?
Follow steps below:
1. Navigateto the Start -> All Programs -> Accessories -> System Tools program group.
2. Clickon the System Restore programicon.
3. ClickNext > on the Restoresystem files and settings window.
4. Choosethe restore point that you want to use.
Note: Check the Show more restore points checkbox tosee more than the most recent restore points. Note: Any restore points that you created, scheduledrestore points that Windows 7 created, and those created automatically duringthe installation of certain programs will be listed here. You can not useSystem Restore to undo Windows 7 changes to a date that a restore point doesnot exist.
5. Click Next >.
6. ClickFinish on the Confirm yourrestore point window to begin the System Restore. Note: Windows 7 will shut down to complete the SystemRestore so be sure to save any work you might have open in other programsbefore continuing.
Important: System Restore will not revert any of your non-systemfiles like documents, email, music, etc. to a previous state. These types filesare completely unaffected by System Restore. If your intention with this toolwas to recover a deleted non-system file, try using a file recoveryprogram instead of System Restore.
7. ClickYes to the Once started,System Restore cannot be interrupted. Do you want to continue? dialog box.
8. SystemRestore will now restore Windows 7 to the state that was recorded in therestore point you chose in Step 4. Note: The System Restore process could take several minutesas you see the "Please wait while your Windows files and settings arebeing restored" message. Your computer will then reboot as normal whencomplete.
9. Immediatelyafter logging in to Windows 7 after the reboot, you should see a message that SystemRestore completed successfully.
10. ClickClose.
11. Checkto see if whatever Windows 7 problem you were troubleshooting has beencorrected by this System Restore.
Jan 30, 2011 | Computers & Internet
I am having problems loading my zynga poker, which until 3 days ago loaded fine, now it just freezes part way though loading, my husband plays his zynga poker on the same computer and his loads fine .help
Have you tried doing system restore to restore your computer to a certain date when it was still working fine?
FOR WINDOWS 7 and VISTA Operating System
1. Click the START MENU
2. Type in System Restore in the search area.
3. Click on the Next button. (See screenshot below)1058d1229784383t-system-restore-restore.jpg
B) Go to step 5.
4. If You Have Done a System Restore Before -A) Select (dot) Choose a different restore point, and click on the Next buton. (See screenshot below)1060d1229784383t-system-restore-restore_point-2.jpg
5. Select (click on) a listed restore point that you want to restore Windows 7 back to. (See screenshot below)
NOTE: Check the Show other restore points box to see any restore points (older) that may not be listed here. 1054d1229784383t-system-restore-system_restore.jpg
6. To Show Affected Programs and Drivers -
NOTE: This will show you a list of programs and drivers that will be deleted and restored by the selected restore point.A) Click on the Show affected programs and drivers button. (See screenshot above)
B) When done reviewing, click on the Close button. (See screenshot below)1055d1229784383t-system-restore-affected_programs.jpg
7. Click on the Next button. (See screenshot below step 7)
NOTE: Make sure that the restore point you want is still selected (highlighted).
8. Click on the Finish button. (See screenshot below)1053d1229784383t-system-restore-confirm.jpg
9. Click on Yes to confirm. (See screenshot below)
WARNING: This will immediately restart your computer to finish the system restore.1056d1229784383t-system-restore-last_chance.jpg
10. After the computer has restarted, click on the Close button. (See screenshot below)1057d1229784383t-system-restore-after_reboot.jpg
FOR WINDOWS XP OPERATING SYSTEM
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
I hope this helps. If this fix doesn't work. Don't hesitate to leave your message here.
PLease don't forget to leave your comments and ratings for this post.
Thank you so much.
Carlo
var geo_Partner = 'cca8460f-a562-4792-a693-6fa0e7fcde78'; var geo_isCG = true;
Sep 25, 2010 | Computers & Internet
Crosley Radio Pictograph Slide Negative Scanner 1 ea Logo
734 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
Lawrence Oravetz
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
