Question about Panasonic Televison & Video
All channels great reception; BUT no sound. Mute has been toggled to no effect. Any ideas? Panasonic TX-32l32
  • wuwuw Nov 29, 2010
    Did all the above recommendations, nothing. No sound. Called cable company to reboot cable box. Nothing. I am out of ideas...
    Habit-Forming:
  • 146 Answers
It's very possible that your tv has a speakers on/off function in the audio menu, I would check there first. If you use a cable box for reception the sound may be off from the box to tv, try volume up on the box. If you have a box reboot both the box & tv by unplugging both from wall outlet for 30 seconds then try again.
Posted on Nov 29, 2010
    Did all of the above. No luck. Called cable company to refresh cable signal. Nothing. I am out of ideas :-( Anyone?
  • Joe LeBlond
    Joe LeBlond Dec 02, 2010
    Last possible idea would be to eliminate the cable box. Remove the cable in wired from the cable box and insert directly to the tv. If you have sound the box is at fault. If not, I recommend a service pro to check the audio circuit on the digital main module.
6ya staff
SOURCE:
Antenna
Really tough to get perfect reception with Rabbit ears. If you can somehow feed the line outside a lot of the times I have found that it helps improve signal reception
Jan 25, 2013 | RCA Ant121 Indoor Passive Antenna
I have a Panasonic Viera 32" LCD-TV TX-32LX70 TV and the volume suddenly goes load and after a while it returns to norrmal. any one have any ideas/ thank you
Well it could be the sound amplifier or a cold solder joint on the sound amplifier , Does the remote have any effect? or the buttons on the front? It also could be the jack in the rear to the tuner is loose, the cable.
Jun 30, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Just bought an RCL3210 TV. The odd thing is that the Channel up/down key on the remote control does not change the channel. Also, the up/down channel key on the TV itself also does not respond. When you...
You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
May 08, 2017 | RCA Televison & Video
Samsung Exit TTX mode
Had to reset the TV and re-tune all channels. But it worked.
Feb 02, 2010 | Samsung DynaFlat TX-P3064W 30" TV
Panasonic lx-32lxd70 lcd tv not working in cyprus?!?!?!
Under the channel setup menu there should be a way to change the input type of the channel. When you go to edit a channel look for this setting. If all your channels are grainy this is probably the solution also.
Jun 15, 2009 | Panasonic TX-32LXD70 32 in. HD-Ready LCD...
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
Televison & Video Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
