I am looking samsung driver for my monitor , model no is sync master 591s , from where i can get this driver , if you have solution for this kindly mail us at [email protected].
There could be number of reasons, the main one being a power issue. There may be one or more bad capacitors on the circuit board. These can be replaced by someone who knows how to repair electronics but since this is a CRT monitor you need to be very careful about the dangerous voltages inside the monitor.
Considering the age of the monitor you are better off spending the money a decent LCD monitor.
If you shake it and it comes back on, then first thing to look for is bad connection, cable, solder joints. Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague http://www.badcaps.net
This eventually happens to all CRT monitors. Either the flyback transformer or some other critical componant has failed, and the screen cannot produce a picture. It might be an easy fix, but it would be better to get a new one.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages. Good Luck!
