Question about Brother M 4318 Matrix Printer
Check error - Brother M 4318 Matrix Printer
Posted by giuseardu on
  • Anonymous Nov 29, 2010
    clearly can you say what is your problem
Sudeep Chatterjee
  • 3,267 Answers
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Posted on Nov 29, 2010
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
Mar 13, 2018 | Washing Machines
I have hoover Optima wmh139 with lights flashing from left to right it's 1 2 5 how do you read fault
here are what the numbers mean. 5 is probably throwing the others but you'll need a service tech to know for sure.
have you unplugged/cut off power to it for 10 min to see if it may possibly reset? Worth a try anyway.
Error 1 Door safety lock error
  • Check door is closed and latched correctly
  • Check wiring
  • Check door lock
  • Check drum braking device if fitted
Error 2 Not filled in preset time allowed - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
Error 3 Not drained in time allowed - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Error 4 Multiple instances of anti-flood contacts in pressure switch being made
  • Check for overfoaming evidence - can trip pressure switch
  • Check pressure switch is not defective
  • Water inlet valve locked open
Error 5 NTC fault - temperature sensor detected as either open circuit or shorted
  • Check wiring to temperature sensor
  • Check thermistor
Error 6 EEPROM failure - defective electronic controller
  • Check wiring
  • Check electronic control PCB
Error 7 Motor fault detected
  • Check motor connector block
  • Check wiring
  • Check motor carbon brushes
  • Check tacho connections
  • Check motor
Error 8 Motor tacho fault - washing machine motor tacho detected as open circuit or shorted
  • Check wiring
  • Check motor
Error 9 Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Error 12 Communication error between electronic control boards and wiring
  • Check wiring and harness between control boards
  • Check electronic control modules
Error 13 Communication error between boards and wiring
Error 14 Water heating error detected
  • Check wiring to wash heater and thermostats
  • Check wash heater for continuity
  • Check NTC (temperature sensor) probe
Error 15 Defective control module - Not programmed Cuore control
  • Reprogram electronic controller
  • Replace electronic controller
Error 16 Water heating element detected as short circuit
  • Check for defective electrical insulation
  • Check water heating element
  • Check water heater wiring
Error 17 Wrong signal from motor tachometric generator
  • Check wiring
  • Check motor
Error 18 Defective control module - also can be wrong electrical input frequency
  • Check wiring to electronic controller or both if two used
  • Check electrical input frequency
  • Check mains electrical supply
Feb 26, 2018 | Hoover Washing Machines
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Error code f15
Error F15 Motor Control Unit (MCU) Error
If the MCU detects multiple resets or errors during a wash cycle it will go into this error mode.
Potential Causes
- Check wiring harness connections to the MCU, the motor, and Central Control Unit (CCL)
-Check Drive belt
-Check MCU
-Check Motor
-Check Wire Harness
Good luck.
Oct 17, 2011 | Washing Machines
45682 error code f 15
Potential Causes
-Check Drive belt
-Check MCU
-Check Motor
-Check Wire Harness
Good luck.
Oct 17, 2011 | Kenmore Washing Machines
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Xerox 8550 showing error code 11,009.46:31197 how do i fix it without paying extortionate xerox callout
  • Check that all system grounds are secured.
  • Check or reseat all connections to the Electronics Module.
  • Check the condition of all harnesses.
  • If the problem persists, follow the procedure below.
  • Check ground integrity for the printer.
    Does the error persist?
    Go to Step 2.
    Complete.
    Reseat all system interconnections and check that the cables are properly dressed.
    Go to Step 3.
    Complete.
    Reset NVRAM.
    Locate the error code below.
    Complete.
    For errors 11, 001.47 and 11,017.45
    Replace the Tray Lift Motor.
    Replace the Electronics Module ( REP 5.0.5).
    Complete.
    For errors 11,002.48 and 11, 016.44
    Check the Option Tray connection.
    Replace the optional tray.
    Complete.
    For errors 11,003.49 and 11,0014.42
    Replace the I/O Board ( REP 5.0.13)
    Complete.
    For errors 11,004.41 and 11,013.41
    Replace the I/O Board ( REP 5.0.13).
    Replace the Control Panel ( REP 1.0.9).
    Complete.
    For errors 11,006.43 and 11,015.43
    Replace the Printhead ( REP 2.0.2).
    Complete.
    For error 11,009.46
    Complete.
    For all other 11,000.4x errors:
    Complete.
Apr 09, 2008 | Office Equipment & Supplies
Brother M 4318 Matrix Printer Logo
212 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
