Question about Brother DCP-9040CN Laser Printer
How to remove a paper jam brother printer - Brother DCP-9040CN Laser Printer
Posted by jonathan_lu6 on
Michel Smith
  • 1,218 Answers
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Get more information and help for Brother Carriage Jam .
Posted on Nov 29, 2010
How do I remove a stuck paper tray
Some useful adivic:
Frequently Asked Questions
Clear paper jams Brother
How do clear paper jams Brother
If you still can't remove stuck paper, it's REALLY stuck. Take it to a repair service. apart of removing all that paper, they should diagnose WHY you got a mega-stuck.
Forced removal might damage your printer
Aug 27, 2015 | Brother MFC 3360 INKJET MULTIFUNCTION...
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Printer paper jam
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 24, 2014 | Brother DCP 130C All-In-One InkJet Printer
Check paper error
Sir/Madam
I Think There is paper jammed in the printer.
Action:
Press button A, open the front cover and remove the jammed media.Make sure that there is no paper jammed in the paper trays.
Or Still Having Brother Printer Problem The Follow Us For On: Brother Printer Support
Jan 23, 2014 | Brother MFC-8840D All-In-One Laser Printer
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
Apr 03, 2010 | Brother HL-2170W Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Aug 20, 2007 | Brother HL-2040 Laser Printer
Brother DCP-9040CN Laser Printer Logo
813 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
