Kenmore Elite 45986 Front Load Washer Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Anonymous
Level 2:
Scholar:
  • Expert 116 Answers
  • Posted on Nov 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
116
Questions
0
Helped
31603
Points
395
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
My ht3 #4292 is leaking water from the door
If water is coming through the door bellow and into the tub and not the floor, this is commonly caused by a water inlet valve that is leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem to determine which one is causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I included parts resources and instructions on how to replace each component as well.
If you have water leaking on the floor, you may also have a bellow with a rip or tear. If the bellow is leaking, it must be replaced. Pull back the rubber folds and inspect the entire perimeter around the door to be sure. If the bellow needs replaced, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about any of these repairs, please post back and let me know. I hope this helps you.
I have Kenmore Elite HE3 Front Load Model 110.5862400. The rubber gasket/bellow got wadded up with clothes and popped out along with the clamp. How do I put back together. There is no damage but I don't...
The following link explains the steps required to install a door bellow on a front loader:
Inspect the bellow and the front and rear clamps to ensure they are not damaged. If the bellow has any rips or tears, it must be replaced or it will leak.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer can contribute to items getting caught in the bellow and causing premature wear. Follow the manufacturer's recommendations for proper loading.
1helpful
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
8helpful
2answers
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
My kenmore elite front loader leaks
well you can remove teh boootm acess panel by removingthe 3 screws that run along the bootm of the unit . afete rthat you can set a cycle to wash ans see where the leak is coming from
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
1helpful
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
1helpful
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Alexander
vince
