Had same problem. Unscrew the back of the TV. Unscrew 2 screws connecting VCR/DVD from TV Base. Unscrew DVD housing on all sides (approx 6 screws). At this point you can see the detached DVD unit. Facing the DVD drawer. Look under it for a white plastic piece that you can slide to the right that should disengage the DVD's circular rotator from the dvd and slide the door open.
If that does not work disconnect the DVD from the 2 connectors at the TV motherboard. Slide slack into the ribbon cable to free up the case. When the DVD unit is out, dissassemble the black plastic DVD unit. Flip it over and manipulate the white plastic gear which will disengage the center rotator.
Let me know if that works for you.
