IBM ThinkPad T41 Notebook Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My IBM T41 laptop will not boot up! When i press the power button all the lights come on then only the crocked Z with a circle and d battery lights stay on! What should i do?
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Nov 29, 2010
Anonymous
Expert
Level 2:
Answers
62
Questions
Helped
9926
Points
141
Try to remove your keyboard and fix it back. Seems like the keys are getting struck. You could search in Youtube of how to remove and fix the keyboard back on the laptop.
1helpful
I seem to be locked out of my ibm thinkpad t41 it wont let me switch it off or access ibm
Locked out how? With a password? You can't switch what off? Press and hold the power button until it shuts off or Just unplug it and remove the battery as a last resort. With no power source, it will cut off.
My T41 no boot, no sounds, only the fan turns on!
The motherboard is most likely damage. First remove the battery, make sure it is unplug, and press and hold the power button for 30secs. Than put the batty back in and see if it helps. If this doesn't, try removing the hard drive and memory and see if it turns on. If not than the motherboard is dead.
2helpful
4answers
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
My ibm t41 just freezen and is not working at all
try to turn it off, pressing the power button for 10 seconds.
that should do it.
if that doesnt work, disconnect the ac plug, then remove the battery.
wait 30 seconds and start it again.
Ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
2helpful
Messed with Boot sequence.Now T41 won't boot!
With the cd reboot and press F12 for a temporary boot list, select boot from cd. At this point just choose install xp and follow the prompts.
IBM ThinkPad T41 boot-up problem
Hello, enter BIOS (by pressing "Delete")and find there restore default. If you drop it you need check inside laptop of connections components. Check Cpu or Ram.
IBM T41 No power
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Installing a pc computer power supply
Once no power supply is installed into the computer, place the new power supply into the computer and screw the screws into the back of the power supply.
POST troubleshooting steps. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.
Good Luck, Please dont for get to Vote/Thank You.
IBM T41 Power issues?
Could a MoBo failure or nothing more that a connector- solder problem. I depends on your abilities- take it apart and have a look or Send it to a repair shop or Take it apart- shudder put it back together then send it to the repair shop ;-)
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
