General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
Posted on Nov 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it is fine. I removed the filter certrige and no help. The water runs in fine but once its in full filter the water flow will stop completly. I have 60 psi coming in.
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Nov 29, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319577
Points
3041
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
  • Anonymous Nov 04, 2011
    Try removing both of the filter elements to see if water flows through the filter canisters. If water flows OK. Re-install one element at a time to see which one is causing the restriction. If flow is OK then insure both filters are installed at the same time. If flow is restricted with both filters then use only one filter & canister. You now have a spare. Check the micron rating of the filters to see if they are rated for your intended use. Why use two filters? Water is filtered to an extent in the water softner. Anything collected is wash out when the resin tank is backwashed.
4helpful
4answers
Geospring water heater keeps beeping even though filter is clean
Same thing happened to my GE Hybrid Geospring Water Heater. Luckily, I bought the extended service plan from Lowes. The problem is a leaking evaporator coil in the heat pump (top portion) of the water heater. Believe it or not, the evaporator coil may be freezing up due to low refrigerant levels, which triggers the filter alarm. GE knows all about this problem, and it is covered by the 10 year warranty FOR PARTS. Labor is not covered, even though this is a big defect. Unless you bought the extended warranty... You will need an HVAC service tech to fix this problem, preferably one who works for GE Appliance services. Last, but not least, owners need to report this to the Consumer Product Safety Commission (CPSC.GOV), as in my opinion A RECALL IS IN ORDER HERE. After all, the thought that 410A refrigerant is leaking into my home (my water heater is in our multi-purpose room) is ANYTHING BUT SAFE!
I installed the GXWH40L water filter. My repairman said now only hot water is coming out of my garden hoses. What happened?
Hi Installed incorectly...You have gravity by-passing (flow) into the cold water pipe.Maybe have a check valve installed to stop flow during stand-by time. thanks
I have a ge smartwater filter system #GXWHO4F. My problem is that since system was installed the water pressure and the water volume drops alot when more than one faucet is turned on.The filter system...
Filters always reduce pressure.
You can add a pressure tank between filter and tankless.
Tankless are sometimes like bowling on a ship.
Add a comment saying how you fixed problem.
Fix most tankless problems yourself, same day, all brands for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
We also installed the water filter GXWH40L. We never had any issues and have gone through probably five replacement filters. We recently changed the filter and have horrible water pressure. We changed it...
Check the micron rating on the filter. A typical filter will be 30-50 micron. If the new filters are a finer micron 5-10 these will reduce the water pressure significantly and plug up much faster. Also note if you have more sediment occurring. If on a well, hook a hose up to the drain at the well tank and flush the tank out to a floor drain, take note of any sediment, let the well kick on several times to flush completely.
RJ
If you have GATE valves on either side of the filter make sure the have opened all the way. They can become unscrewed and although it seems like it opened they gate can be almost closed. If the outside spigots are on hard water try the pressure there.
Water filters for pre-filter housings come in different micron ratings. They can be anywhere from .5 micron on up to 100 micron. The smaller the number the finer particulates it filters out and the faster it will plug up. Generally most filters used for residential households are 5 micron to 50 micron rating and the most common used are 10,30 or 50 micron. Try a 30 or 50 micron filter to see if it helps. But remember the larger the micron rating the more particulates pass through.
If there is a lot of sediment coming the well and building up in the bottom of the pre-filtet housing you may want to flush the well or consider having the well inspected by a well company. You could have a pinhole in the drop pipe that is letting sand in.
Run one of the outside spigots in to a clean white bucket, let the pump cycle several times and inspect for sediment in bucket, let it settle for about 20 minutes to see if excess sediment is coming from well. Have your water tested to see if the water chemistry has changed also.
RJ
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
22helpful
5answers
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
Top General Electric Water Heaters Experts
Paul Carew
ADMIN Eric
ADMIN Eric
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
