Question about Honda Landa PG 3500 PSI Pressure Washer
Honda 13 hp will not start, will run on starting spary, new spark plug, has knocing noise before stopping
Posted by acleq1 on
Aron Kerr
    Scholar:
  • 45 Answers
If this machine has been sitting for an extended period of time it is likely that you have a couple of things going on. First you should drain the fuel from the gas tank. Next remove the bowl from the carb and using a flat head screwdriver remove the mainjet from the carb. Check that it is clear then re-assemble. Next pull your spark plug. Put a rag over the hole in the head where the plug was and pull the engine over a few times. Re-install the plug. Now remove the grey oil dipstick from the engine and check for the oil level being over full. If it is drain the excess.
Doing all of this should solve your issue. In most cases the problem you describe is caused by varnished / rotten fuel, a faulty carb float allowing fuel to drain into the crankcase creating excess pressure or water buildup in the cylinder creating excess pressure.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
Honda engine 13hp no spark on plug
Start by changing plug. Make sure to ground plug to engine when testing for spark. After go after cable. If resistance is on you'll need to check magneto or coils
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Dec 16, 2015 | 13 HP Engine GX390 OHV Horizontal Shaft
Charged batrie pet in checked spark plug plenty spark .turn key on not firing spary some east start still nothin
Check 3 things
Spark
Compression
Fuel
I always start with fuel because that will eliminate spark and compression right off the bat...
Spray some carburetor cleaner into the plug hole then reinstall the plug ..
If the unit starts up and runs for a few seconds, you have a carburetor issue
Oct 15, 2015 | Garden
1998 Valkyrie/1500 stock. Owned since new. I run with high octane premium gas. The past two years my Honda has become more difficult to start. Cold weather stops it from starting at all. Took it to a...
Hi, Arm_1951 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
hard starting valk
Valkyrie Cold Starting Procedure
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 17, 2017 | 1997 Honda F6 C Valkyrie
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Saw was running and quit checked gas and oil both are full
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bike wont start. everything works. no spark on plugs
98 honda shadow ace wont start electric switch is sticking and the headlight doesnt come on when key is turned on
May 04, 2009 | 1989 Honda VT 1100 C Shadow
1992 honda accord stop running in middle of driving
When you turn the key to start, the engine cranks over? You must check for spark and fuel, if one is missing, the car won't run. Pull a spark plug, with plug wire connected and plug on a metal surface of the engine, have someone turn the key to start, while you watch for spark at the plug. It is easiest to see spark with car out of direct or bright light. If you have spark, attempt to start several times, pull a spark plug and check for evidence of fuel (wet) on plug. Let me know what you find, we can then continue.
Apr 16, 2009 | 1992 Honda Accord
Honda Landa PG  3500 PSI Pressure Washer Logo
418 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
