The train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Sounds like the motor is jamed up,,strip it down and free off motor
The drive is a worm system and the wheels will not turn. One very,very important thing is that the aluminum track leaves particals on the rubber bands of the large drive wheels. Believe it or not, it will conduct the track current into the large drive wheels which are metal and cause just enough of a short to cause the train to only move a short distance and stop. When using the set alot in December, the wheels will have to be cleaned often. I use track cleaner and very,very fine sand paper and also keep the track clean. You will see what appears to be aluminum color on the rubber if you turn the engine upside down. One way you can tell if this is a problem is have someone hold the engine so the wheels are off the track and turn it on. If it runs fine, this is the problem. This problem can also make one feel like the remote is the problem . Any questions, my name is Tom and my cell is 717-487-4328. I live in central Florida
