Question about Maytag Dishwasher
The cable to the door of my GE Potscrubber 900 dish washer (model GSD900L-02) broke. I purchase the replacement cable and now need to know how to reinstall this new cable. The replacement parts include two cables and two springs. Can you provide a "visual" of how this cable connects to the lower left corner of the door???
Posted by trmfreiman on
Anonymous
    New Friend:
Question, my cable just broke yesterday. Where did you buy the part?
Posted on Dec 13, 2010
GE Potscrubber 900 just runs and runs, dial just sits there
Hello Debbe,
Does the dishwasher fill with water, or is full and fails to drain?
Can you provide additional detail so that we may accurately troubleshoot? Also include the complete model number. It should be etched or stamped on a plate inside the door, or elsewhere on the washer.
Thank you!
Jan 30, 2018 | GE Dishwashers
Ge potscrubber 600 the washer arm is not cleaning dishes on top shel
Remove the arm and clean it. It is surprising how much 'stuff" gets in to them and blocks the holes.
Aug 12, 2014 | Dishwashers
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
GE Diswasher Mod# GSD900L-01. The guide wires attached to the springs on the door have broken. Need to get new wires, and instructions how to re-attach the wires to the springs and the door. Thank you.
The door cable is here:
http://www.appliancepartspros.com/part_details.aspx?part_id=2038829
I don't have the instructions on the how to replace it. It is a matter of replacing them one at time as best you can with the door closed. I do not have a manual for this dishwasher to pass you any pictures. Just being honest.
Kelly
Oct 05, 2010 | Maytag Dishwasher
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
Hello I have a GE Advantium 120 model no. SCA1001KSS 02 man. Jan 08 I caught my coat on the door and broke one of the hooks that is monted on the door, and hooks into slots in the face of the oven....
You can purchase that part directly from GE, go to
www.geappliances.com click on parts and accessories tab, enter your full model number and then follow the menus to the part your after,you will be able to see the cost and order it directly from this site. Good luck!
Nov 24, 2009 | Ovens
GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Sep 12, 2009 | GE Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag Dishwasher Logo
747 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
