Question about Roberto Cavalli RC 451 Sunglasses
My sunglasses frame broke i need address for repair
Posted by rhonda_reed on
Anonymous
    Scholar:
  • 103 Answers
Sir
your sunglasses are branded Roberto Cavalli RC 451 Sunglasses so i request you to take the sun glasses to the show room where you brought it . they will have solution to your problem for sure.
if youare satisfied with my answer plsvote 3 thumbs up for it
Posted on Nov 29, 2010
I broke the arm on my Kenneht Cole sunglasses, where can I take them to get repaired
Unfortunately KC does not offer replacement parts for their glasses. If they are a year or less they should fix those under the "year warranty" through the manufacturer.
Feb 13, 2014 | Kenneth Cole Reaction Sunglasses
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Ray ban rb4105 folding wayfarers the grey hinge on the brdige broke. the frame is alright so I think i just need to get that 1 part replaced.
please help me!!!!!i cant find a spare part for the hinge on the bridge of my wayfarer folding...what can i do???
Sep 06, 2011 | Ray-Ban RB 4105 Sunglasses
I need to purchase legs for my nike flexon 4083 eyeglass frames. color 718. I do not need anything more than the legs. I paid well over $600 for these frames and have had to resort to crazy glue for...
Hi Curtis,Did you ever find any arms for your glasses? I have the same frames in the 718 color with a 140 length arm that the nose/bridge broke on.BC
Jul 10, 2011 | Nike Flexon Sunglasses
Where can I send Dior sunglasses for repair?
hi
Repairing an expensive pair of Dior sunglasses does not have to be complicated. A return to the retailer they were purchased from will simplify the process. Dior sunglasses are sold with a one year warranty on manufacturing defects, which means they can be sent back to the manufacturer for repair. Simple Dior sunglass repairs may occur through local repair centers.
    Check Your Warranty
  1. There are two ways in which to work with Dior sunglass repairs when the glasses are under warranty---through the retailer and through the manufacturer. Repairs are not generally made by the retailer if the item is within warranty, although simple repairs, like missing screws or loose parts, may be made by some retailers on site. The retailer can send the glasses to the manufacturer for the customer or will give the customer the address to do so. The customer can also go directly to the manufacturer by calling Safilo (Dior's licensed manufacturer) at 877-228-5818 begin_of_the_skype_highlighting 877-228-5818 end_of_the_skype_highlighting and requesting assistance. Safilo will then provide directions on where to send the sunglasses. Safilo will repair items that are out of warranty but this may require paying for the repair.
  2. Purchase Repair Kit
  3. Simple repairs can be made at home using a sunglass repair kit. These kits contain a variety of screws, nuts and nose pieces. They also contain a tool to assemble and tighten the repair with. Repair kits are not usually made for a specific manufacturer like Dior. Kits will only supply the pieces for simple repairs and not proprietary parts like nameplates or decorative attachments. Sunglass repair kits can be found through most eyeglass and sunglass stores. They can sometimes be found in variety or drug stores, too. The kits can contain a mixture of gold tone and silver tone parts or may contain only one or the other.
  4. Find Local Repair
  5. Local eyeglass repair can be found in many eyeglass centers and through frame sellers. Personnel in these stores are often trained to make simple repairs. LensCrafters and Pearle Vision are two of the many choices for walk-in sunglass repair. Having sunglasses repaired through these retailers may be ideal when the warranty has expired. Sometimes retailers will not charge for simple repairs. If the customer has purchased a specialty part directly from the manufacturer but does not know how to attach it, a local repair center may be able to assist in the repair
If you are happy with my answer please vote four thumbs up. Thank you
Dec 12, 2010 | Clothing Accessories
I HAVE A PAIR OF A18 GOLF SUNGLASSES. AHILE REMOVING THEM FROM MY HEAD THE HINGE WHERE THE ARM MEETS THE LENSES SNAPPED AND BROKE, INSTEAD OF SIMPLY DETACHING AS ADVERTISED. I PROBABLY NEED A NEW FRAME....
hi
i am sure that must have hurt you ,let me see what i can do to fix your sunglasses . ok here are few suggestion which will help you out
1) try contacting any dealer who deals with sunglasses i am sure they have frames for your shadeds or visit the sites below it shall help you
http://www.coolframes.com
http://www.sunglassreplacementlenses.com
hey if your sunglasses are in warranty please contact the dealer where you brought it ,it will be done free of cost
Dec 09, 2010 | Adidas A18 Golf Sunglasses
Left side broke
hi
The question you have asked is not clear and specific, but let me try to help you. The left side of your sunglasses is broken it may be your lens or frame,
The solution is if your sun glasses have warranty or guarantee please approach the showroom where you brought shades or you can approach some other dealer showroom they may not have your brand but they will repair it for a charge.
If you are satisfied with my answer please vote three thumbs up ..Thank you
Dec 02, 2010 | Guess Clothing Accessories
I have a raquel sunglass frame - TF76 692 . I broke the piece that goes over the ears close to where the plastic touches the metal. How do I get this repaired?
respected sir,
the only way your problem can be solved is to take it to show room where you bought it or to some other shop which deal with sunglasses . they have the required equipments to repair .i request you not try anything by your self the damage may increase
if you are satisfied with my answer please vte for it
Nov 29, 2010 | Tom Ford Clothing Accessories
Roberto Cavalli RC 451 Sunglasses Logo
312 people viewed this question
Top Roberto Cavalli Clothing Accessories Experts
JonSnell Electronic
JonSnell Electronic
legerdress
legerdress
Bandage Dress
Bandage Dress
Are you a Roberto Cavalli Clothing Accessory Expert? Answer questions, earn points and help others
