Yes, it's a very common issue for your model camera. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Ooops, just noticed that you have an S1 IS. You're likely experiencing CCD failure instead of a stuck shutter. Please see the following link instead. Canon will fix this issue for free regardless of warranty status. Copy and paste the link into your browser:
http://camerarepair.blogspot.com/2007/11...
