Intel D945GCNL Motherboard Logo
Posted on Nov 28, 2010
Ddr3 ram is supported on this motherboard or not
Philip Norris
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Nov 28, 2010
Philip Norris
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
18004
Points
90
Biostar A55ML2 Motherboard. Not accepting ram upgrade to 2x8GB DDR3 PC3-12800 1600Mhz.
OLD RAM WORKED, iMPLIED?
Not accepting? MEANS BIOS WILL NO ACCEPT IT?
OS GOAL,no OS told
FAILING AT THE bios LEVEL, TRY RESETTING BIOS
DO NOT NOT SWAP RAM WITH AC POWER CORD ATTACHED OR BLOW IT UP YOU WILL, LEAVE THE AC CORD OFF FOR 1/2HOUR
SO ALL CAPS DISCHARGE FIRST.
SPEC: 2013 MADE . BIOSTAR ENDED SUPPORT.
Socket FM2 (amd.com ended support)AMD A55 CHIP.
2 DDR3 DIMM slots
Up to 32 GB
Dual-channel DDR3-800/DDR3-1066/DDR3-1333/DDR3-1600/DDR3-1866/DDR3-2133
POWER OFF, AC CORD REMOVED, LET IT DISCHARGE
FOR 15 TO 30 MINUTES
test old ram first the new.
do not mix RAM sku (models)
try them all 1 by 1 , in bank 0 channel A slot
in sert one the plug in AC power cord last
then go to BIOS first even have HDD unplugged
and do this bios reset
https://www.pcdied.com/cmos.html#Reset_only.
see if bios likes each stick if yes
try them all (both) at once for 16GB .
some modern RAM, do not run on old PC/mobo
due to density rules violated;.
The chip set must like the DDR
the BIOS too.
1helpful
2answers
What to do if i have a motherboard which doer not support ddr3 ram
You can either look for the correct ddr memory for your system or upgrade your current board to a ddr3 compatible one
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • 0helpful
    Will my shuttle fd30 plus motherboard support a ddr3 gt 430 video card and a ddr3 memory card?
    Yes it will support DDR3 GT 430 Graphics card.
    But it will not support DDR3 RAM.It only supports DDR2 RAM.
    Thanks for using FixYa.
    2helpful
    2answers
    Will my Gigabyte GA-8I915P Duo Pro Motherboard take ddr3 and ddr2memory upgrades
    This motherboard can take a DDR2 RAM , this are the supported RAM for it Dual Channel DDRII 533 / 400 or Dual Channel DDR 400 / 333.
    GA-X58A-UD3R what ram does it support ???? gigabyte site is hard to find anything about their suport list of ram options
    Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500, DDR3 PC3-12800, DDR3 PC3-17000, DDR3 PC3-14900 with a maximum of 6GB kit (2GBx3) per slot.*
  • 240-pin DDR3 DIMM Banking: 6 (2 banks of 3)
  • Chipset: Intel X58
  • DDR3 SDRAM Frequencies: PC3-6400, PC3-8500, PC3-10600 and PC3-17600
  • Error Detection Support: Non-ECC only
  • Graphics Support: Quad PCI Express x16
  • Max Unbuffered DDR3 SDRAM: 24576MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR3 SDRAM only
  • USB Support: 2.x and 3.x Compliant
  • From crucial.com
    2helpful
    Can i upgrade my ram to ddr3 if so what would you recomend .cheers
    Thank you for the clarification sir.
    NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
    This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
    This is the support page for the Fujitsu Scalio 600 Media Center,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
    Uses either DDR Sdram at 333MegaHertz, or 400MHz.
    (PC2700 and PC3200 respectively)
    DDR Sdram has 184 gold plated contact pins on the bottom.
    DDR2 Sdram has 240 gold plated contact pins on the bottom.
    DDR3 Sdram has the same amount of contact pins as DDR2.
    The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
    This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
    So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
    You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
    Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
    Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
    Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
    'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
    Which is better 1gb ddr3 rams or 3 gb ddr2 rams?
    No dubt about that! I would have take the 3gb ddr2 ram!
    In a couple of years from now, when everything supports DDR3 i would have taken the DDR3, but today i take 3gb DDR2!
    Nic
    Top Intel Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
