Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Can the lens on a rca rear projection get dusty and cause blurry word and images?mostly words on my video games are unreadable ..xbox is hooked up via componite cables..running at 1080i..i have tried auto setting the convergence repeatly,,and also manually setting the cponvergene
Chi Chu
  • RCA Master
  • 8,457 Answers
All ur convergence + - colors lines matches up wright?Yes.Than no,this problems are ur CRTS tubes colors guns R,G,B have bad CRTS coolant chemicals.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to changes those CRTS coolant chemicals,should solved ur tv problem.
Posted on Nov 28, 2010
Testimonial: "awsome..as i have now found the stuff and a guide to fix my tv...thanks"
  • 2 more comments
  • Anonymous Nov 28, 2010
    yes all lines match up perfectly and stay matched up..
  • Chi Chu Nov 28, 2010
    Yes,as i said ur tv have CRT Tubes coolant problems.
    i found the crts coolant faily cheap 22$ a bottle enough for 1 tube..how many tubes are there to be done where would i find guide on doing this? or is this not for a do-it yourselfer..
    They're all very simular design in CRTS,buy the Philip CRTS coolant kits it cost $85.It have chemicals for all three CRTS Tubes coolant chemicals for all three CRTS.It also came with a DVD instructional tutoring,show u how to do it.
Bud Martin
  • 11,361 Answers
Just FYI; Compoiste video jack (Yellow RCA video input jack) is not capable of hi-def video signal, it is only for LOW RES SIGNAL. May be you are talking about Component video input (RED/BLUE/GREEN RCA jacks). Just to let you know.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 03, 2010
  • Bud Martin
    Bud Martin Dec 03, 2010
    By the way, I still have this TV at my house, the convergent adjustment on this TV is very limited at best for the edge of the pictures adjustment.
The picture does not seem as bright as it was
This rear projection from the model number appears to be a RCA AND not the zenith listed in your question.
If RCA the lens for the tubes may be dusty or dirty--should be cleaned once a year.
Process is simple: unplug set and remove rear cover.
Locate the three large black lens at top of chassis and either with a lens cloth or a paper towel with glass cleaner sprayed on the towel clean them.
If they are dirty/dusty they will make picture look darker and duller than it once was---they are the light source for your picture.
Mar 18, 2012 | Zenith Televison & Video
52 rca bottom left corner words are blurry but fine every where else when you play a video game It almost looks 3d to
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
What would be causing my 360 not to read discs
a dusty lens buy a lens cleaner for the 360 and just run it in the 360 (the lens cleaner is 10 or 15 dollars most of the time)
Nov 19, 2009 | Microsoft Xbox 360 Console
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Televison & Video
No problem just have question for the experts.
Games are fine on a rear projection or LCD TV, it is the old tube type and the new plasma TV's that get burned in images and ghosting. Even they can be used you just have to be careful to select games that don't have a stagnant background that can cause a burned in image.
May 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in RCA
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
http://servicemanuals.vstore.ca/
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46921. Just changed flyback.
if nothing has been tampered with ie. focus controls, lens focus, I would check to make sure the high voltage lead is seated correctly.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
RCA Rear Projection Blurry Picture/Popping Sounds
Might be a bad CRT, might be a bad focus block, I would refer you to a Repairman as it will take some experience to repair.
Jul 10, 2007 | RCA P52921 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
624 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
