SOURCE: I bought a DX-UBDB9 ysterday.
OK IF YOU HAVE A MAC THE DISC HAS YOUR DRIVERS IT SHOULD AUTO LOAD OR TELL IT TO INSTALL FROM DISC.WINDOWS DOES NOT NEED IT(THE DISK)JUST HOOK UP AND USE.RICHARDM69
SOURCE: dx-ubdb9 serial to usp
So you mean to you cannot find the drivers for this device to work. I guess you wrote hardware instead.
http://www.dynexproducts.com/pc-197-2-dynex-16-usb-pdaserial-adapter-cable.aspx
You can click on the above link, and click on the button chat now , and the support tech from dynex would give you the required help.
Thanks
Proton
SOURCE: lost cd to my dx-ubdb9
If you follow the address below, it will get you to the dynex website. typr the model in the search and you will be directed to the download area.
www.dynexproducts.com/t-drivers.aspx
Hope this helps
SOURCE: I cannot install the device
Search for "PL2303_Prolific_DriverInstaller_10311.zip" these have worked for me
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Yeah. I pulled the cable out of mine, too.
Did you have any luck fixing yours?
