Question about Car Audio & Video
How to replace power steering pump impala 2000,engine 3.4
Posted by krstopavlice on
Dcramer531
    President:
  • 1,654 Answers
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt from the power steering pump pulley. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
5. Remove the power steering pressure line from the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L)
6. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Remove the power steering pump mounting bolts from the power steering pump.
8. Remove the power steering pump assembly.
9. Remove the power steering pump pulley from the power steering pump. Refer to Power Steering Pulley Replacement.
10. Remove the power steering pump reservoir from the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
2. Install the power steering pump pulley to the power steering pump. Refer to Power Steering Pulley Replacement.
3. Position the power steering pump assembly to the engine. Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts. Tighten the power steering pump mounting bolts to 34 Nm (25 ft. lbs.).
5. Install the power steering pressure line to the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L).
6. Install the power steering return hose to the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
8. Lower the vehicle.
9. Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L
10. Fill the power steering system. Refer to Refilling the Power Steering System.
11. Bleed the power steering system. Refer to Bleeding the Power Steering System.
12. Inspect the power steering system for leaks. Refer to Steering and Suspension Leaks.
13. Remove the drain pan from under the vehicle.
You may want to take it to the dealer or other repair shop. It is very difficult and will consume a major portion of your day.
Posted on Nov 28, 2010
Where do I put power steering fluid in my 2000 Chevy impala?
The service info should be in your owners manual.
Normally the power steering tank is on the pump or close by.
The pump should be on the passenger side of the engine near the top.
Jan 16, 2013 | Cars & Trucks
Where is the power steering pump at.
The power steering pump runs off of the fan belt. It should be near the front of your engine.
Feb 03, 2011 | 2000 Chevrolet Impala
Coolant leak
leaks in this vicinity are usually from the seals going bad on the water pump. It's next to the PS pump, and is very common to leak there in any vehicle. Look at the pulley for the water pump, do you see streaks on it leading out from the center? This will confirm it. Recommendation: replace your water pump.
Feb 21, 2010 | 2000 Chevrolet Impala
How do i put power steering fluid in my 2000 chevy impala
With engine off power stering pump located on engine. remove cap. cap will have a dip stick attached add "GM" power stering fluid a little at a time. wipe dip stick clean reinsert and remove check by using the high oil line the the marking on the dip stick. do not over fill
Jan 22, 2010 | 2000 Chevrolet Impala
Where is the power steering pump on the 2000 Impala 3.8 6cyl engine? We need to add more fluid.
its on the passanger side rear towards the firewall.....down low.....you will need a long funnel to add fluid to the resevoir....available at advance auto
Dec 23, 2009 | 2000 Chevrolet Impala
Where ia the powering pump fpr a 2000 chevy impala
if you have a hydraulic power steering pump it is located on the side next to the firewall and serpentine belt. useing a flash light may help.if your steering is electric there is no fluid.the electric motor is under the dash on the drivers side. hope this helps.
Nov 13, 2009 | 2000 Chevrolet Impala
Power steering whinning in 03 Impala
how can i take of a power stering from impala 03
Sep 13, 2009 | 2003 Chevrolet Impala
Whats the estimated time to replace the power steerring on a impala 2000
it shouldn't be right now because the car is fairly new give the car 3-4 more years before you would want to change it but if you aint having a problem with the power steering pump or hearing any noises from it i wouldn't change it.
Jul 02, 2009 | 2000 Chevrolet Impala
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
