SOURCE: Keurig B100 not pumping a cup of water through
in the water tank you have 2 sillicon tube one of them is stretch at maximum and usaly strech in 2. cut the part split and connect it again. the probleme is because the silicon left is propryety when is strech in very hot water. the best way to slove this problem is to find about 1 in of silicon tube of 1/4 or 3/16 iner and put the new parts of tube directly on the bafle and put the original tube in the new on. it just make a link betwen the bafle and the original tube. put teflon tape on the fitting of the bafle to avoid of the new tube spout out from the fitting.//// but take care and other touble can cause this the pump can be jam because the one way valve on the side of the brewer jam open because is to teith in in is body. check all is thing .if you need somthing eles y will comme back on the site soon :0)
SOURCE: my kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
I think the magnetic valve is defective. This is located on the left side (seen from behind inside the machine) and there`s connections between the thermoblock and the hot water outlet. Try to press the steambutton and check if the magnetic valve clicks, and maybe check with a voltmeter if it`s receiving power.
PS. During steamprocessing the pump just have small ticking sound, and not the same sound as during brewing. There is no way around this Fill system message, and the reset function is not activated until any System Messages has been clared.
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
