If you have the original fuses you might be able to tell from that. For example are there remains of a coil? If so it's a slow blow.
However you can fit fast blow in there, it should work normally with that. If it blows again it will be an short in a semi-conductor that causes it not the fuse type.
Krell KAV2250 uses 12 amp, fast blow fuses (AGC12) for the speakers. They are there to protect the AMP from overloads
