Hi Raviseetha,
This is the issue with the Laptop Charger, your charger is faulty.
I would recommend borrowing a friend or family's laptop charger that works on your laptop and see if it works. If it does not, then the problem could be something internal circuitary and you should ask Compaq to fix it. If it charger works, then the problem is definitely the charger, possibly because it is not providing enough power which would usually happens all the time with most of the laptops
If you laptop is under warranty,I am pretty sure if you ask Compaq to replace the parts or fix them if necessary. Else you could buy a new charger and it would fix your issue..
This should solve your issue.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this solution.
Thanks For using FixYa!
Vinod Kumar J
