Question about BOSS AUDIO SYSTEMS BV9560B Car Video Player
When i was trying to calibrate the touchscreen i got the touchscreen out of calibration and now i can't get back into the OSD set up because the touch screen dosen't work. I tried to use the remote but it doesn't have a function for that. i also tried pressing the reset button. BOSS AUDIO BV9560B
Posted by timothymo602 on
alex
    Problem Solver:
  • 9 Answers
Oh that's a hard one. You can try having it on and unplugging the power to get it to restart if the button won't.
Posted on Jan 17, 2018
1 Related Answer
Anonymous
  • 96 Answers
SOURCE: where is the reset button
Click on the link below to view the BOSS audio BV9560b user manual, inside the manual it will show you where the reset button is located:
http://www.retrevo.com/support/Boss-Audio-BV9560B-Car-Videos-manual/id/23353ci554/t/2/
Posted on Feb 04, 2011
How do i calibrate my nextbook tablet
You can adjust the touchscreen calibration by going to Settings-->Touchscreen calibration on your Nextbook.
Calibrate touchscreen
  • SO THIS HAS HAPPENED TO ME ,WHAT I DID WAS GO TO SYSTEM SETTINGS AND FIND THE CALIBRATE APP IF YOU DON'T HAVE THAT GO TO THE APP STORE AND LOOK UP CALIBRATE APP . WILL HELP YOU FROM THERE
I have a samsung reality and im having problems getting it to calibrate right. its the bottom part of my touchscreen that i have trouble calibrating.
hi sdi black841 take the battery out of the phone then put it back in . Next go to your settings and go to calibrations on your phone.this should help you
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
1helpful
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
1helpful
My harmony touchscreen remote is working intermittently. sometimes taking out the batter works but it is not working now.
try recalibrating the lcd. to do this, please follow the steps below:
One can incorrectly calibrate the remote by pressing areas on LCD other than the ones marked during the calibration process.
Solution
To re-calibrate a remote which has been incorrectly calibrated, please follow these steps:
  1. Put the remote in safe mode.
    1. Remove the battery
    2. Hold down the System Off button on the remote while inserting the battery back into the remote
    3. Continue to hold the System Off button until the remotes LCD has lit up and reads Safe Mode
    4. Let go of the power button
  2. Reboot the Remote
    1. Remove the battery once more
    2. Re-insert the battery
  3. Follow the calibration wizard on the Remote to re-calibrate it by pressing on the areas indicated.
1helpful
Calibrating wont work.. i want to reset it.ive cleaned the screen n taken out the battery...help!!!!
You need a new Touchscreen. FAIRLY EASILY to replace.
http://site.powergamingparts.com/RepairNdsl.html
My touchscreen is off point, and my calibration wont work
have you tried reswtting it to factory settings. make sure there is nothing putting pressure on the touch screen. If this soesnt work you may have to replace your touch screen. mysciphoneshop.com offers replacements, but they have to be soldered in be careful if you decide to do this.
3answers
Touchscreen
try calibrating the unit
BOSS AUDIO SYSTEMS BV9560B Car Video Player Logo
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
