Question about Gunvault Multi Vault GV2000 Std
How do I reset code on my gun vault GV2000 - Gunvault Multi Vault GV2000 Std
Posted by wrcreamer on
Curt G
    New Friend:
Enter the 1,2,3,4 factory number.
When the door opens, immediately press all 4 keys are once and release.
A red light will come on. then enter new code. lamp will turn off.
to confirm the new code enter it a second time.
red light blinks, an error has occurred or your timing was off, so just start over with the factory 1,2,3,4 code.
Posted on Jan 06, 2015
1 Related Answer
Anonymous
SOURCE: NO LEARN BUTTON ON GUN VAULT 1000
Here are the Instructions I have to my older (Sept 1998) GV2000-A:
PROGRAM YOUR SECRET CODE:
This will cause the red lamp to come on, so programming can begin.
Note: Avoid doing this in bright light.
Enter your new secret code. The lamp will go out.
Now immediately confirm your new Secret Code by entering it a second time.
If the red light blinks, an error has occurred or your timing was off, so just start over with the factory 1,2,3,4 code.
Posted on Mar 29, 2009
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
I forgot safewell vault's code but have the key the vault's no. 09002820
Write the Manufacturer and maybe try to list in a section of Fixya that is not a Cars and Trucks section.
Oct 17, 2012 | Cars & Trucks
How do I reset code on multi vault gv 2000
I went here for your manual:
Do you have the key?
Looks like you can remove power for 30+ seconds and reset to the factory defaults (there's external power and AA batteries inside.)
The PDF file linked above has the "learn" precedure for setting the code. And there's a FAQ list on page 13 that you might find helpful.
:o)
Jan 04, 2011 | Gunvault Multi Vault GV2000 Std
Code setting instructions for GunVault
Hi, I found something on amazon, take a look: Amazon com gun vault manual Have a nice day
Mar 11, 2009 | Gunvault Multi Vault GV2000 Std
Jan 25, 2009 | Gunvault Multi Vault GV2000 Std
Gunvault Multi Vault GV2000 Std Logo
3,710 people viewed this question
Top Gunvault Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Gunvault Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
