Question about Canon PowerShot A530 Digital Camera
My cannon a 530 says that it has a memmory card error, and it shows memmory card locked momentarally at bottom of screen, i tried to unlock with the slide on the card itself, but that did not help. i put a new memmory card in and it shows the same. i also noticed a watch type battery next to the aa batteries, could that battery be the problem ? i have never changed that battery and this camera is several years old.
Posted by finalround51 on
CameraR
  • Canon Master
  • 4,738 Answers
No that's not likely the problem. The new card is probably the issue, especially if it is 4GB or higher. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Nov 28, 2010
After selecting allow speech over locked screen, my nokia lumia 530 is locked please how do I reverse that?
Hard Reset NOKIA Lumia 530 - HardReset.info
www.hardreset.info/devices/nokia/nokia-lumia-530/
Hard Reset NOKIA Lumia 530; In the next step go to Windows Phone Settings. Master Reset NOKIA Lumia 530; Afterwards select About. Wipe data NOKIA ...
nokia lumia - Phone is locked and says I need to wait for ...
windowsphone.stackexchange.com/.../phone-is-locked-and-says-i-need-t...
Sep 9, 2013 - I locked myself out of my phone by entering the wrong password too many times. However, instead of the usual "Try again in 1 minute" ...
How to unlock Nokia Lumia 530 - sim-unlock.net
sim-unlock.net > Unlock Nokia
Your Nokia Lumia 530 is locked to only one network ? You can unlock ... Check how fast You can unlock Nokia Lumia 530 by using our site. We give You full ...
Nokia Lumia 530 - How to unlock security code by hard ...
? 13:44
https://www.youtube.com/watch?v=q8OjYvinAxo
Nov 11, 2014 - Uploaded by phone reset
look i forget my password of my nokia account so i reset mylumia 635 it works? or how i can erase mi nokia ...
Jan 05, 2016 | Nokia Cell Phones
EVERY PICTURE I CLICK ON SAYS LOCKED IN MY SANYO 14.0 CAMERA
if your problem is seems in ur memmory card..you can try after unlock ur car...there is a small key in the memmory card's side for lock and unlock...
Nov 24, 2012 | SanDisk 2GB microSD Memory Card
How do you get card locked off
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Samsung Digimax 530 Digital Camera
Cannon s2 digital camera used. i inserted a new memory card and have an error showing memory card error. card not locked!
trying removing it and unlocking it with the unlock button.. they some times lock them selves when you slide them in the slot.. go slow and straight.. this sometime fixes the problem... Good Luck.. T.
Jun 21, 2011 | Canon Cameras
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 10, 2011 | Lands Phones
I forget my phn code of n72. And i want to format my phone. My memory card is courapted now what i should do. I forget my memory card pasword plz help me.
HI, U CAN UNLOCK YOUR PHONE. FOLLOW THE INSTRUCTIONS-----1) DON'T TURN OFF THE PHONE 2)REMOVE MEMMORYCARD FROM LOCKED PHONE AND PUT IN AN MEMMORY CARD READER. CREATE DIRECTORY E:\SYSTEM\RECOGS AND COPY THC-NOKIA-UNLOCK.MDL INTO THIS DIRECTLY...... ORYLY 3)REMOVE MEMMORYCARD AND PLASED IT INTO LOCKED PHONE...THE THC-NOKIA-UNLOCK-PROGRAM WILL START AFTER 120 SECONDS 4)REMOVE BATTERY AND MEMMORY CARD .PUT BATTERY BACK AND RESTART ...THE PHONE LOCK IS RESET TO 12345.TO FORMAT YOUR PHONE USE THE CODE *#7370#.MEMMORY CARD CAN BE FORMATTED BYU SING THE CODE *#7780#..THANKS
Nov 18, 2010 | Nokia N72 Cellular Phone
Data of memory card not display and show the message `Memory card not formatted'
IT IS DUE TO YOUR MEMMORY CARD CORRUPTED
1)FORMAT MEMMORY CARD AND TRY AGAIN
2)IF THAT SEE THIS ERROR YOUR MEEMORU CARD BUSTED
REPLACE IT
Nov 16, 2010 | Nokia 3110 Cellular Phone
'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Mar 04, 2010 | Canon IXUS 80 IS Digital Camera
How to unlock my memory card
On side of The SD card there is a little lever that slides up and down this is the protection lock. PUSH it all the way to the top. Sometimes when inserting it gets caught and will move just enough to have the camera consider it locked. So be careful when inserting it.
If this does not fix it try another SD card or reformat it.
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | Cameras
Card locked
Hi...
If your card is locked try to remove the card. See if there is a small button there and slide it to unlock the card. Put your card back to your DG cam.
Good luck.
Regards
PCmania
Sep 01, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A530 Digital Camera Logo
73 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
halotheracer
halotheracer
Are you a Canon Camera Expert? Answer questions, earn points and help others
