You may have a bad Vehicle Speed Sensor [VSS] This sensor provides the information the speedometer needs to indicate speed and also supplies the transmission with information it needs to determine when to shift. If the signal is lost you can end up with the very symptoms you are having. It's usually located on the rear of the transmission or transfer case area. Hope this helps!
