Question about Amana DK25 Dehumidifier
I need a new filter for my amana dk25 dehumifidier does anyone have a part number
Posted by gunbergs on
Robert Moller
    Guru:
  • 1,524 Answers
Call Bi Coastal Appliance Parts @ 1-800-673-1262
Posted on Nov 27, 2010
Is there a recall on this product? My compressor and fan run but no water is collected. I know other Amana dehumidifiers were recalled for fire risk due to compressor overheating so I took cover off and...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
Has there been a recall on this product? My compressor seems to run but no water is collected. I took the back cover off and the compressor is extremely hot and I know that other Amana dehumidifiers were...
What numbers do i set the digital screen on? on the amana dehumidifier D 965E-E
If you want to remove a lot of moisture/humidity, set extraction level on 35%. That's the arrow down button. If you want to remove less moisture/humidity raise the extraction percentage level.That's the arrow up button.
Hope this helped you. Please let me know. Thanks.
Jun 02, 2011 | Amana Dehumidifiers
Need to replace a gas manifold for an Amana GCI 90A30 gas furnace. The part number, D6995003 is an obsolete Maytag part number since Goodman bought out Amana. I either need to find a source for the part or...
You could Purchase the Part from :-
http://www.apwagner.ca/index.php?main_page=product_info&products_id=486717&language=en
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 27, 2010 | Amana Dehumidifiers
Amana 30 (looks like dk25) unit runs but coils freeze up
Most dehumidifiers have a defrost mode in which the compressor is turned off to give time for the frozen water to melt. The freezing problem ocurrs when the unit is used in very cold weather. Check your manual to see if this unit comes with automatic defrost mode. If it does, it would appear that it is not operating correctly and you can request warranty service. If no defrost mode is available, then your only option is to heat up the room in order to use the dehumidifer within its limit of operation. Some units can operate as low as 36 F, but most units cannot go that low. Find out what your unit's specs are from the manufacturers web site.
Jan 04, 2009 | Amana D530M Dehumidifier
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Should I clean or replace the air filter?
You can wash the filter with water, no problem. However, I would recommend replacing the filter every 3 to 4 months depending on how much you use the dehumidifier. The exposure to constant moisture will cause the filter to grow mold over time.
Jul 27, 2007 | Amana DK25 Dehumidifier
Amana DK25 Dehumidifier Logo
48 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
