Question about New Bright Small Holiday Express Train
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the transfomer. Train set is +-10-12 yrs old. I have 2 sets. Both have the same prob. Any suggestions short buying a 3rd set?
Posted by abrahamcordo on
Kerry Cunningham
    Habit-Forming:
    New Friend:
  • 66 Answers
Check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
Posted on Nov 24, 2017
5 Related Answers
zaldyboy01
Bonnie Quintos
  • 293 Answers
SOURCE: No power to track and/or train. Power to Holiday Express Train
Check the power circuit that goes to the track if there is an open circuit, open circuit means, break or cut line that can not flow the current going to the track to give a power to the train, ok.
Posted on Nov 27, 2009
Testimonial: "Thanks for your help. David"
Bob Moody
  • 14 Answers
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Posted on Dec 16, 2009
Anonymous
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Posted on Dec 19, 2009
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
Anonymous
  • 5 Answers
SOURCE: an electricalroblem with Holiday Express train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
Anonymous
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Posted on Dec 28, 2009
New Bright Holiday Express train No. 380 won't run or even light up
You need to fault find with a multimeter before guessing what to change.
Dec 22, 2017 | Televison & Video
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
Dec 18, 2009 | New Bright Small Holiday Express Train
Train powers up,lights go go.Press forward and it just buzzes.Doesn't move. New Bright said it's the 'Tender Car ".
The tender car supplies power from the track to the entire trian.
Make sure the train will run with just the Loco and the tender. Make sure the tender is securely plugged in to the Loco and make sure the the brushes under the wheels on the tender (this is how power gets from the track to the train) are in contact with the track. Finally use a scotch brite pad (DO NOT USE STEEL WOOL) to clean up the track a little.
You can also take a volt meter and measure for DC between the rails. You should have about 10.5VDC on the track. (Inside rail is neg on mine and outside is pos) ...
Hope this helps..
Bob
Dec 05, 2009 | New Bright 384 Holiday Express Animated...
Where can I buy a track clip for my New Bright
New Bright does not offer any replacement or repair parts for thier products.
They have a 60 day replacement warranty, but after that, you are on your own.
Nov 28, 2009 | New Bright 384 Holiday Express Animated...
Dec 22, 2008 | New Bright 384 Holiday Express Animated...
New Bright Small Holiday Express Train Logo
376 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
