Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
If the green light reacts as you state then the chances are the fuses are fine.
Again, with the reaction of the green light being as you stated i'm going to assume you have a problem with one of your screens, tell me... when the green light comes on does one of the screens flash? If it does then we have found the answer...
The screen that doesnt flash is the one with the problem, you can try taking the DS lite apart and re-connecting the screens ribon to see if that sorts it, if it doesnt then im afraid you will have to buy a new screen. These can befound on ebay for a reasonable price.
I have written some guides on how to change your screens and how to disassemble the DS lite, these will guide youthrough the processes you need to take. These can be found by clicking on my name and then scrolling down to "tips and tricks", press the "view all" to see all of them and find what you need.
You should check your ground fault and reset if necessary. This particular swimming pool light should cycle through a variety of different light shows by turning the switch on and then off for no more than 10 seconds. If it is not cycling properly, you might be leaving the swith off for longer than 10 seconds or your bulb might have malfunctioned.
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
black = ground dark green = lights on input grey = panel lights pink = on input yellow = power input orange = battery power input
nca = shield ground tan = left fr spkr + orange/black = left & right spkr -neg lite green = right fr spkr +
nca = shield ground dark blue = right rear spkr + dark green/yellow = right & left spkr - neg brown = left rear spkr +
purple/white = display dim output pink = vehicle speed input ----------------------------------------------------------------------- **** 91 park ave without delco bose =
grey = left front - neg tan = left front + pos dark green = right front - neg light green = right front + pos
black = ground dark green = display dim signal grey = panel lights pink = power antanna yellow = ign input orange = battery power light blue = right rear - neg dark blue = right rear + pos yellow = left rear - neg brown = left rear + pos .
