SOURCE: plantronics 2XX pair code
The pairing pin should be 0000, most bluetooth device's use all 0's.
Hope this help's.
SOURCE: neither 0000 or 1234 work as Motorola t305 passwords
Reset button is a small soft rubber circle near the on/off button.
SOURCE: PAIRING PLANTRONICS BLUETOOTH WITH IPHONE 3G
On your phone. goto the Bluetooth menu and select "Add Device or Add Headset"
Refer here to put the headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator
begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
