*NOTE* This answer was actually found on another source.
If resetting the OSD doesn't work, then you probably have a physical problem with your Menu button. Sometimes, particularly on older machines, the connections to the circuit board are dirty or failing. Because you have to actually get into the monitor itself, you will probably void any remaining warranty by attempting this fix. If your monitor is still under warranty, contact the manufacturer to see if there is a local repair shop that can help you. If you want to tackle this issue yourself, grab a screwdriver and take the plunge. Remove the casing on the monitor itself and locate the contact switch for the menu button on the circuit board. Sometimes, just working it with your fingers or a screwdriver is enough to unstick it - you can try to clean off any dust or grime that has accumulated around it to see if that is the cause.
The easiest solution to try is to reset the on screen display in the menu. Hold down the Menu button (it is probably marked Ok) for at least a minute. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section. On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
Hold down the Menu button for 10 seconds.
SOURCE: osd main controls locked
my intex svga 17" crt monitor has two osd controls. One of them is usable but i don't know how to use the other one. probably the other one can be accessed through button combinations. I dont know them please help me. I really need it as that contains more functions
SOURCE: help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - [email protected]
Thanks
SOURCE: philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
SOURCE: OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
