Samsung TXN3071WHF 30" TV Logo
Question about Samsung TXN3071WHF 30" TV
I accidently pulled out the coax connector out of the back of my Samsung model txn3071whf while trying to move the set without disconnecting the coax cable. Is there anyway I can fix it without having to take it to a repair shop? I'm very handy and have a saudering iron. Do I need the whe little tunner box or can I just get a replacement post and sauder it back in. I just got the TV from a friend and it otherwise works great. I'd hate to have to throw it out and can't afford a repairman or to replace the set. Please help walk me threw this if you can. Thanks for your help and feedback. Sincerely, Christine Hartley, Anchorage, Alaska ps-theres a Radio Shack rite down the street if that will help for parts. Happy Holidays.
Posted by akwildcat196 on
5 Related Answers
Anonymous
  • 934 Answers
SOURCE: Samsung PS42P3S
Not quite enough information here to know what cables your friend needs, but let me stab at this anyway. The HDMI Digital Video/Audio cable is a part number D2412-DDMI6. It's a six foot cable. The IF cable on the other hand is Samsung p/n# AA39-30007B. Does he have the user manual? It should list the cables he is trying to find in the accessories section along with any Samsung part number. Then just go to Samsung Direct at http://www.samsungparts.com and order it... If he doesn't have a user manual he can order that too. Hope this helps. Bill
Posted on Jun 05, 2007
Anonymous
SOURCE: Samsung HLR5668WX Light Engine
It is not the light engine, it is the light tunnel. The tunnel is four small pieced of crappy glass in a aluminum tube the size of tootsie roll. I took mine apart today and one of the mirrors simply moved out of place. Need more help email me at [email protected]
Posted on Sep 19, 2007
Anonymous
SOURCE: Bad transformer on Inverter Board
for me I think I'm gonna try Decision One a certified Dell fixer upper. I looked at my inverter and there were no burns that I could see. My problem is different from Headstrongs come to find out. Dell w3201c is the model number, it has samsung on parts under the hood....
good luck
Posted on Jan 15, 2008
Anonymous
  • 192 Answers
SOURCE: Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Posted on Dec 22, 2008
Jaime Hernandez
  • 2351 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to [email protected]
Posted on Jan 05, 2009
The part that you hook the coax cable to got pulled out accidently.how do i put it back??
It depends on how the connector was connected to the tv set. if it was mounted on a pc board, you'll have to solder a wire from the connector to the pc board.
1helpful
Hooked up cb, blows fuse when the mic is keyed
when mic is pressed transmitter is engaged. First is the Fuse the proper fuse? Could be an antenna-coax problem. Get a dummy load and hook up to your CB and try it again. If it doesn't blow the fuse, the problem is indeed in your coax antenna system. another way to test your antenna coax is to disconnect it from the radio, take a multimeter, set it to ohms 200 ohm scale, put one lead on the center pin of the coax and the other on the outside of the connector on the coax.if it shows anything at all, you have a short and that will not work. It needs to not read anything. To be sure the antenna system is ok other than swr you can also check the coax an antenna for continuity. one lead of meter on the coax center pin then other on the antenna. should get a reading, a low value. again on the outside of the coax at the connector and at the antenna side on the outside of the coax connector. should be a low reading. but you cannot have a reading from the center of the coax to the outside of the coax. disconnect the coax at the antenna and measure from center to outside at the coax if the previous reading showed a value.If you see a value on the meter, any value, your coax has a short. not good. most likely at the coax connector. redo the connector. It is possible that the coax got compromised somehow and got smashed to the point the outside coax meets the inside and touches.
Now the other possibily your fuse blows, kis because the final output transistor is bad. So if you hook up a dummy load to your radio and the fuse still blows, then the final transistor is bad. This is probably due to a bad coax-antenna system. So before you replace any parts check the coax-antenna system first or you will have the same problem and burn out another transistor in the final. If none of this helps then just get another radio or have a god buddy look at it that knows about radios. Trade him another radio or something to fix it.
Broken Coax connector on samsung un46c8000
I have the same issue. Did you ever find out how to fix this problem.
Thanks,
Steve
4helpful
How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
2answers
My 2002 bmw 525i has broken front seats. When I
This is a common BMW problem before giving to a mechanic try looking at the mechanism to see if any bolts are loose or missing,you might find the bracket is broken or torn and needs to be welded or replaced,the job is relatively easy but be carefull because of the SRS system if not sure give it to an expert.
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Samsung TXN3071WHF Problem
When the set is on, the red light should be off, not on...
2answers
TXN3071WHF Samsung
it sounds like stereo mode is comming on and off , you will need to go into the audio options for network box and adjust the sound options , Hz e.c.t and i would also suggest to retune the tv stations , another thing , im not sure how u have it set up , on the back of the network box there should be FL/front left FR /front right output plug holse , e.c.t Audio out , plug the cords into these holes and the other end of the cords plug into tv at the back AUX , Audio In , R / L , red /white , let me know how you go , if you need more help i will be happy to assist
No Power...
did u check the fuse in the set. if so check the power supply section
4helpful
2answers
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Marvin
Marvin
