If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature
In most refrigerator freezers, the refrigerator
gets its cold from the freezer. The evaporator fan circulates air
over the coils in the freezer and cold air circulates into the refrigerator
through vents. If the vents are blocked or closed, then the fridge
will not get cold enough but the freezer will. If neither is cold
enough, then the number of possibilities increases.
Lowering the freezer temperature will increase
the cooling cycle activity. Setting the refrigerator temperature
may have little affect on the cooling cycles because it simply changes
the vent opening size. Decreasing the fridge temperature opens the
vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls
found inside the refrigerator or freezer. The ideal freezer temperature
is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water
with a cooking thermometer into the refrigerator for about 2 hours
or more. To
test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
