Question about 2wire (1000-400108-001) Router
Welcome to Fixya
There should be no problem in setting up a passkey for this device. Try to restore the router to factory default first and try to setup again the passkey.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Nov 29, 2010
Here's a link on how to connect your vista to a wireless router. make sure that the authentication is same as the router. If the router uses a WEP or WPA, you should use the same with vista.
http://www.vista4beginners.com/How-to-se...
have you double check the authentication that you are using? The authentication key should corresponds to your router. if your router is using WEP or WPA. Your computer should be using that one also.
Go to the routers home page and go to wireless security. below is the link on how to setup your vista to connect to router. Take note of the drop down arrow ehere theres is WEP or WPA options.
Oct 17, 2009 | 2wire HomePortal® 1800HW Router...
Jul 11, 2009 | 2wire Computers & Internet
Jun 27, 2009 | 2wire (1000-400108-001) Router
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Mar 18, 2009 | 2wire (1000-400108-001) Router
Feb 02, 2009 | 2wire (1000-100016-002) Wireless Adapter
Jan 28, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Jun 15, 2008 | Computers & Internet
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Nov 02, 2017 | 2wire (1000-400108-001) Router
138 people viewed this question
The pass key is not the problem. I called my IP and even changed the pass key. I think it has something to do with Windows Vista and the WEP setup. I need step-by-step instructions on how to make my computer OS accept a secured setting before entering the pass key.
Cannot get a secure connection with 3800hgv-b 2wire gateway with a 302.11n wireless USB adapter. When it's an unsecure connection I can get connected. Only when there is a secure connection, it won't connect. Using Windows Vista. The pass key / wireless network key is not the problem. The problem is compatiblity of the computer accepting a secured connection.
Used thehttp://www.vista4beginners.com/How-to-se... link but the problem still exists. I think it may have something to do with the wireless configuration utility. When I was on the phone with my IP, they turned off the secured setting and I could get connected so, it's not a router problem. I'm also sure it's not a pass or security key issue.
How do I verify if the router is using WEP or WPA and how do I set the computer to the same?
