LG WM-1832C Front Load Washer Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG frontloader runs thru majority cycle & towards the end it stops & flashes "LE" code. I have replaced Hall sensor.
Richard Roth
Level 3:
Top Expert:
  • LG Master 9,472 Answers
  • Posted on Nov 26, 2010
Richard Roth
LG Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628726
Points
28464
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process. The reason this particular unit has been on the injured list for so long is the first tech never followed a trouble shooting process to ensure the parts being replaced had actually failed.
1helpful
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me [email protected] please put hall sensor in subject line. Thanks
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
2answers
2005/2006 model LG Troon washing machine. Washing cycle ok, spin cycle stops incomplete and LE shows on didgital display.
Kevin
2answers
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
1helpful
2answers
Code LE, will not finish the spin cycle
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My LG washer is flashing LE and won't contiue the
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
2answers
Le error code
IE means that it is taking too long to fill up.
2helpful
Cycle stops after a few minutes,LE flashes on screen
Washing stops after a min or two & LE flashes up!
This is caused by an error from the hall sensor on the motor. It is possible that one of the connectors has come loose (this is an issue with LG's or it could be the hall sensor it's self is bad. First check that the harness that connects to the motor is tight. If that doesn't help then the hall sensor will have to be replaced. The hall sensor is located on the motor. The hall sensor basically tells the computer which direction and what speed the drum is turning.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
