Question about Kenmore Sewing Machines
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length at 2 which is always beside S.S. which means this is always set on Straight STRETCH. How do I set the two so they are different?
Posted by linmlee on
teddibear10
    New Friend:
  • 35 Answers
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Posted on Nov 27, 2010
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
Does my kenmore sewing machine Model number 5151 do zig zag stitch?
I was able to find this photo on the internet. If your machine looks something like this
http://www.worthpoint.com/worthopedia/strong-vintage-kenmore-sewing-machine
Kenmore sewing machine in cabinet model 117 305 Collectors Weekly
Photo gallery Stitch in Time Must Liquidate EstateSales org
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=25&ved=0ahUKEwjXk5Gy3ZTMAhXhyIMKHaaSA_w4FBAWCEEwBA&url=http%3A%2F%2Fwww.searsarchives.com%2Fhistory%2Ffiles%2Fsewing_id.pdf&usg=AFQjCNEavJEwfhMVnix2pT0kwej_RSZ33A&cad=rja
then it most likely has zig-zag. There are a lot of dials and levers on this machine. Most straight stitch machines have only one or two. One dial/lever with numbers from 0-4 or 5 would be the stitch length. The other dial/lever with numbers from 0-4 or 5 would be stitch width, which would make a zig-zag stitch.
Apr 17, 2016 | Kenmore Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
How do i get a straight stitch on my golden touch & sew model 640 machine
Check for diagrams on the selector wheel and then adjust your stitch length. Do not set to tight as your thread will break
Oct 02, 2014 | Singer Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
What are the best settings on the 4 dials for the straight stitch? Do the ones on top have to match the wheel settings below? Thanks from a novice
#1- tension settings, set this to "5" and leave it
#2- width control setting, 0 would be straight while 5 would be the full width of the stitch (would make a wide zig zag)
#3- Length control, larger the number, longer the stitch. (usually you will set this from 1.5 to 2.5)
#4- Stitch selector, match up the number with the stitch you want to sew. If you want to use the lower row of stitches (14-25) set the length dial to "ss". (ss stands for stretch stitch, such as for #14 (three rows of straight dashed lines) instead of just sewing one stitch forward, the machine will sew back and forth giving you a stretchy stitch/stronger)
Let me know if you need more help :) Chris
Jun 11, 2010 | Brother XL-2600
Singer Model 6212c only sews in reverse... Just brought this machine home today. Ha Ha, it only sews in reverse mode.
there's probably nothing wrong with your machine.
check and see if your stitch length setting is set to Stretch instead of somewhere between 2 and 3.
If it's in the stretch zone (below 0), it can sometimes sew backwards unexpectedly depending on what stitch you have selected.
make sure you have selected a straight stitch, and then select the highest stitch width and a stitch length of somewhere between 2 and 3.
it will most likely work fine.
Apr 02, 2010 | Sewing Machines
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Feb 19, 2009 | Kenmore 12102
Sewing Machines Logo
422 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
